Scoring conundrum
Posted: Thu Jun 20, 2013 8:57 pm
by Planteater
What do you do if you fire 5 pellets but can only see 4 holes?
This happened to me today. However closely I examine the card I couldn't see an enlarged hole that would indicate two impacts in close proximity. Either I missed the entire the card with one shot or two went through at exactly the same point.
Are there any rules that cover this for formal competitions?
Re: Scoring conundrum
Posted: Thu Jun 20, 2013 11:06 pm
Planteater wrote:What do you do if you fire 5 pellets but can only see 4 holes?
That is a very interesting question and hopefully someone will be along shortly to give us an answer. I have always marked the lowest score X2
Posted: Thu Jun 20, 2013 11:45 pm
by Planteater
I'll scan the card tomorrow and post it here.
Posted: Fri Jun 21, 2013 9:30 pm
I have given this some thought, and have come up with two options:-
1 - You award the missing shot as the lowest score. For example, if you can see 5, 7, 8, 9 then you give it a 5.
2 - You award the missing shot the average of your 4 shot score, rounded down. For example (5+7+8+9)/4= 7.25, which rounds down to a 7.
My preferred option is the first.
Any thoughts?
Posted: Fri Jun 21, 2013 11:21 pm
pmh wrote:I have given this some thought, and have come up with two options:-
That is exactly what I do. Works for me
Posted: Sat Jun 29, 2013 6:42 pm
by benthompson
I score in excess of a thousand cards a year and I've come across this a few times. It can be very difficult to find a close fit two pellet hole and the method I use is to select the most likely looking hole and insert a scoring gauge of the correct calibre and if I can feel any slight sideways movement then I would regard it as a two shot hole. If I can't find the , in this case, the filth shot then I would regard it as as a missing shot.
Having said all that the most common reason that I have come across for a missing shot is a miscount of pellets. If you are convinced that there are only four holes and that you can't have missed the target then you have probably only put four shots down.
Posted: Sat Jun 29, 2013 8:04 pm
Good point about me counting.
I have 5 shot batches marked out in my pellet holder for very reason.
If I am using a tin, I'll always count out the required number in the lid, then double check.
Posted: Tue Jul 23, 2013 11:52 am
by RobinC
its not good practice to just pick a hole, most double holes can be seen with a magnifying glass, the second shot even if exactly on the original hole will "clean" the hole, cutting away the small fibres identifying which hole is the double.
The correct answer is to use a double hole guage and a glass, the double guage is a very fine taper with graduated marks, when put through all the holes it will show the one that has two shots as it will go through very slightly more, there will be an identifiable difference if there is two shots, if they are all the same, then one missed.
The NSRA will have a 4.50mm double guage.
Good shooting,
